[GRASS-dev] [GRASS GIS] #86: d.rast.edit.tcl: doesn't start from wxPython without aspect map
    trac at osgeo.org
    Tue Jun 18 04:30:24 PDT 2013
 Reporter:  hamish                 |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  6.4.4
Component:  wxGUI                  |     Version:  6.4.0 RCs
 Keywords:  d.rast.edit, wingrass  |    Platform:  MSWindows XP
      Cpu:  Unspecified            |
Changes (by hamish):
  * milestone:  6.4.3 => 6.4.4
Comment:
 mandatory aspect map fix and wingrass PATH env work-around backported to
 6.4svn in r56784.
 the d.rast.edit.tcl module gui still never gets the message that the child
 process has returned (both Windows and Linux), stays with greyed out
 buttons until you "X" its window, and the no --overwrite error message
 still ends up in the cmd.exe terminal window, but neither is critical for
 6.4.3 so bumping down the road.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/86#comment:6>
