[GRASS-dev] G7 compile error:
Glynn Clements
glynn at gclements.plus.com
Tue Jun 18 10:52:44 PDT 2013
Johannes Radinger wrote:
> BTW: Can GRASS be configured without ffmpeg support?
FFMPEG support should be disabled by default (i.e. only enabled if you
use --with-ffmpeg).
> What is it needed for?
AFAIK, its only use was to allow NVIZ to save fly-throughs as video
files. I don't think that this feature is available in the wxGUI's
NVIZ component, and the original Tcl/Tk NVIZ is no longer present in
7.0. In which case, there's not much point in enabling it.
