[GRASS-dev] [GRASS GIS] #2009: thumbnails.py failure
trac at osgeo.org
Tue Jun 18 17:10:16 PDT 2013
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: r.colors, v.colors | Platform: All
Cpu: Unspecified |
Changes (by hamish):
* keywords: r.colors v.colors => r.colors, v.colors
Comment:
Anna - the new r.colors module GUI dropdown list looks brilliant. thanks!
The information is right where/when you need it.
Thumbnails in the help page fixed in trunk with r56787.
some observations of further buglettes:
I note in trunk there is some rendering error in the top-left corners of
all the image boxes, manifested as a missing pixel. (in GRASS 6 there
was/is a similar bug in d.barscale + Xdriver)
Another rendering issue to be fixed: the absolute-value limited/libgis
color tables (grey.eq, grey.log, and random) are too big by a few pixels
on the right and bottom sides.
We should do something better with the population palettes, maybe put them
on a log-scale. Maybe the same with the precipitation palette. See the
special rule for population in the old shell script version of the
thumbnail generation script:
http://grasswiki.osgeo.org/wiki/Talk:Color_tables
Finally, this is a clear case where the Xdriver does a better job than the
Cairo driver, compare the thumbnails in trunk with the crispness of the
devbr6 versions:
source:grass/branches/develbranch_6/raster/r.colors/thumbnails
... sometimes you want 1px lines to be exactly 1px wide, and no anti-
aliasing.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2009#comment:4>
