[GRASS-dev] compilation of grass on AIX 7.1
Hamish
hamish_b at yahoo.com
Tue Jun 18 21:10:52 PDT 2013
Markus N wrote:
> - diglib test updated in lib/vector/diglib/
> --> still failing there, we try to understand
hmm, this is quite similar, I wonder if it is related:
"grass: FTBFS on ppc64 and s390x"
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=672719#17
>> Errors in:
>> /build/buildd-grass_6.4.1-2.1-s390x-GTALEw/grass-6.4.1/lib/vector/diglib
>> cd OBJ.s390x-ibm-linux-gnu; \
>> LD_LIBRARY_PATH=":/build/buildd-grass_6.4.1-2.1-s390x-GTALEw/grass-6.4.1/dist.s390x-ibm-linux-gnu/lib" ./test; diff ./test.tmp ../
>> test.ok
>> Killed
>> make[6]: *** [OBJ.s390x-ibm-linux-gnu/test] Error 2
Hamish
