[GRASS-dev] compilation of grass on AIX 7.1
Hamish
hamish_b at yahoo.com
Tue Jun 18 23:48:17 PDT 2013
http://bugs.debian.org/672719:
> > LD_LIBRARY_PATH=":/build/buildd-grass_6.4.1-2.1-s390x-GTALEw/grass-6.4.1/dist.s390x-ibm-linux-gnu/lib"
> > ./test; diff ./test.tmp ../
>>>> test.ok
>>>> Killed
>>>> make[6]: *** [OBJ.s390x-ibm-linux-gnu/test] Error 2
Markus M:
> That seems to me a problem on big endian systems, not related to LFS,
> fixed after 6.4.1. I would recommend to upgrade GRASS to either the
> latest 6.4.3 snapshot or to 7.0.
that's copied from an old bug report; Debian builds of modern versions
are ok for all of alpha, amd64, armel, armhf, i386, ia64, kfreebsd-amd64,
kfreebsd-i386, mips, mipsel, powerpc, powerpcspe, s390, sh4, and sparc.
regards,
Hamish
