[GRASS-dev] G7 compile error:
Johannes Radinger johannesradinger at gmail.com
Wed Jun 19 01:25:02 PDT 2013
Thanks Hamish for your clarification.
I skipped now the ffmeg support in my compilation and now
the make process runs smoothly. :)
cheers,
/johannes
On Tue, Jun 18, 2013 at 11:56 PM, Hamish <hamish_b at yahoo.com> wrote:
> Johannes wrote:
> > Interestingly the compilation was working some days (maybe already
> weeks) ago.
> Right, the code had been changed by a few people to work
> with their local version of libav at the expense of people
> using other versions. So in the last week or so I put in a
> bunch of conditionals to try and make it work for everyone
> using versions from the last year or three. In some cases
> that makes it stricter. The reason that distros are abandoning
> ffmpeg is that the API changes all the time and it is hard
> for the packagers to keep up, so they seem to be transitioning
> to a more stable but-compatible fork, and hopefully these
> troubles become less.
> And yes, for the grass7 code just leave off --with-ffmpeg
> since it isn't used in the wxNVIZ currently/yet.
> regards,
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130619/ab40c378/attachment.html>
