[GRASS-dev] [GRASS GIS] #2008: grass.script's find_program() can't find modules
trac at osgeo.org
Wed Jun 19 04:31:23 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Python | Version: svn-releasebranch64
Resolution: invalid | Keywords: find_program()
Platform: Linux | Cpu: x86-64
Comment(by glynn):
Replying to [comment:1 hamish]:
> actually it works, what I was missing what that the argument needed to
be in [square] brackets. (why?)
Because it's a list of arguments to be passed to the program.
It would be trivial to change the function, i.e.
-def find_program(pgm, args = []):
+def find_program(pgm, *args):
but it would also be necessary to change anything which uses it with
arguments, currently:
* raster/r.colors/thumbnails.py
* vector/v.colors/thumbnails.py
* gui/wxpython/gui_core/gselect.py
* gui/wxpython/gui_core/mapdisp.py
* gui/wxpython/core/render.py
* scripts/i.in.spotvgt/i.in.spotvgt.py
* scripts/r.in.aster/r.in.aster.py
* scripts/i.spectral/i.spectral.py
* scripts/g.extension/g.extension.py
* scripts/v.db.univar/v.db.univar.py
If it's going to be changed, sooner is better than later.
PS: there's no reason for r.colors and v.colors to have near-identical
copies of the thumbnails.py script. It should be moved to tools.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2008#comment:2>
