[GRASS-dev] [GRASS GIS] #2008: grass.script's find_program() can't find modules
trac at osgeo.org
Wed Jun 19 05:03:36 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.4
Component: Python | Version: svn-releasebranch64
Resolution: | Keywords: find_program()
Platform: All | Cpu: x86-64
Comment(by hamish):
Glynn wrote:
> > +def find_program(pgm, *args):
would that allow it to be called like:
grass.find_program('r.sun', 'help')
? (I tried a quick test, it didn't like it)
the goal here is to avoid needless extra typing when the only possible
extra options are the $@'s.
> > If it's going to be changed, sooner is better than later.
i.e. before 6.4.3 is released and we have to stay backwards compatible
with the awkward version for the life of 6.x. I think it is still early
enough to change it everything that uses it if we like to, but the window
is closing fast.
Hamish wrote:
> > > grass.find_program('r.sun,', ['help'])
MarkusN:
> For me that fails even after make distclean:
sorry, I had a typo in it, 'r.sun' not 'r.sun,'.
another question with it: should it be changed to test if the program
exists in the PATH and is executable, instead of testing if the program
returns an exit code of 0? (e.g. "gdalwarp" with no options returns '1'
but 'xml2' with no options returns '0')
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2008#comment:4>
