[GRASS-dev] [GRASS GIS] #2001: wxGUI: traceback when using alternate projection for map display coords
GRASS GIS trac at osgeo.org
Thu Jun 20 03:10:36 PDT 2013
 Reporter:  hamish                    |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  6.4.3
Component:  wxGUI                     |     Version:  svn-releasebranch64
 Keywords:  map display, coordinates  |    Platform:  Linux
      Cpu:  x86-64                    |
Comment(by hamish):
 Anna:
 > Just to note, the slowest part is actually adding the items to the combo
 box, not reading.
 probably the drop down menu is not to useful (takes longer to find the
 number you know than to just type it in). use a spinbox instead?
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2001#comment:4>
