[GRASS-dev] pyGRASS send job to background
Pietro Zambelli peter.zamb at gmail.com
Fri Jun 21 05:42:06 PDT 2013
On Friday 21 Jun 2013 13:08:48 Pietro Zambelli wrote:
> Sorry I have to add this in the documentation...
False, it was already in the code... I forgot to activate the foot with the
special parameters... :-)
Now if you ask for the doc in an interactive shell with:
>>> i.albedo?
You get:
Parameters
input: required, multistring
    Name of input raster map
output: required, string
    Name for output raster map
Flags
m: None
    Modis (7 input bands:1,2,3,4,5,6,7)
n: None
    NOAA AVHRR (2 input bands:1,2)
l: None
    Landsat (6 input bands:1,2,3,4,5,7)
a: None
    Aster (6 input bands:1,3,5,6,8,9)
c: None
    Albedo dry run to calculate some water to beach/sand/desert
    stretching, a kind of simple atmospheric correction
d: None
overwrite: None
verbose: None
    Verbose module output
quiet: None
    Quiet module output
Special Parameters
The Module class have some optional parameters which are distinct using a
final underscore.
run_: True, optional
    If True execute the module.
finish_: True, optional
    If True wait untill the end of the module execution, and store the module
    outputs into stdout, stderr attributes of the class.
stdin_: PIPE,
    Set the standard input
env_: dictionary, optional
    Set the evironment variables.
Thank you for the help.
Pietro
