[GRASS-dev] [GRASS GIS] #2008: grass.script's find_program() can't find modules
trac at osgeo.org
Fri Jun 21 11:28:18 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.4
Component: Python | Version: svn-releasebranch64
Resolution: | Keywords: find_program()
Platform: All | Cpu: x86-64
Comment(by wenzeslaus):
Replying to [comment:24 wenzeslaus]:
> I was about to commit the special case for the `explorer` cmd on MS Win.
However, there is also a special case for `xdg-open`, I'm not sure why.
Moreover, I tested also other command and e.g. `firefox` blocks the
g.manual (it also blocks the cmd line when launched without &). On the
other hand, in case of g.manual it opens the requested page, so it means
that it goes behind the `call` function in `find_program`. This confuses
me, I'would expect that the `wait()` call in `call` function
implementation should block the interpreter sooner (i.e. in
`find_program`).
I tested it again and I probably did some mistake before. `firefox` and
`chromium-browser` blocks `g.manual` in `find_program` (browser starts
empty). `xdg-open`, `gnome-open` and `kde-open` works well.
I still don't know why there was special case for `xdg-open`.
Alternatively, we don't need to do `find_program`/`test_program` for
browser, we can just run and report only after `os.execlp` (now there is
an error message anyway).
Replying to [comment:25 annakrat]:
> Why not to have two functions: find_program - behaves like which
command, test_program - or something similar which tests the program by
calling it. For web browsers we could use the which implementation.
Maybe, also the third one for `test_(grass_)module` for GRASS modules?
(Than, we would use `test_module('r.sun')` instead of
`test_program('r.sun', '--help')`) The point is that we need special cases
anyway, so why not to make it explicit.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2008#comment:26>
