[GRASS-dev] [GRASS GIS] #1978: module GUIs: "or enter values interactively" should be opt-in
trac at osgeo.org
Fri Jun 21 11:44:58 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Keywords: parser | Platform: All
Cpu: All |
Comment(by annakrat):
Replying to [comment:2 hamish]:
> If term 2 (element) is "file", trunk's libgis checks to see if the file
already exists & insists on --overwrite. So for file input= and output=
term 2 should probably stay as "file". This also means that the GUI
should use term 2 (element) to decide if there should be a file [Browse]
button present, instead of term 3 (prompt/description) as it does now.
> so that leaves the switch for deciding on a text input box to be based
on the third term (prompt/description). (as far as
gui/wxpython/gui_core/forms.py is concerned)
> so e.g. for r.in.mat we have this info from --interface-description
> <gisprompt age="old" element="mat" prompt="file" />
> `element` would go back to "file", and term 3, `prompt` (aka
description), would change from "file" to "text" (or "bin" or generic
"file").
> And the "or enter text interactively" box would be made to only show up
if `prompt` was "text".
I agree. "file" as element and "text" or "bin" as prompt (this is what you
mean, is it?). Currently it's the opposite way. Apart from "bin", grep
shows also "camera" or "font" - is there any reason to keep them?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1978#comment:3>
