[GRASS-dev] [GRASS GIS] #2015: Missing file association dialog pops up all the time
trac at osgeo.org
Mon Jun 24 13:03:08 PDT 2013
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: All |
Comment(by hamish):
one high profile change in the last week or so is
source:grass/trunk/mswindows/env.bat changed to have
-set GRASS_PYTHON=python
+set GRASS_PYTHON=%GISBASE%\extrabin\python.exe
to match `set PYTHONHOME=%GISBASE%\Python27` a few lines later in the same
file.
try undoing that by hand and seeing if it makes a difference. also, if you
do `echo %PATHEXT%` from ''outside'' of GRASS, is .PY already associated
with a system install of python? AFAIU the official python.org installer
makes some registry changes to set the file assoc. (no different than
resetting it from the command line later, afaiu)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2015#comment:1>
