[GRASS-dev] [GRASS GIS] #2016: v.surf.idw: very incorrect results
trac at osgeo.org
Tue Jun 25 22:36:03 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.4
Component: Vector | Version: svn-develbranch6
Keywords: v.surf.idw | Platform: Linux
Cpu: x86-64 |
I have noticed with some data very bad results with v.surf.idw. The
r.surf.idw and r.surf.idw2 modules do ok with the same data after
v.to.rast of the starting points. But the v.surf.idw results are not
realistic both spatially and numerically.
In my real data I was seeing bad slivering between sample sites, but can
recreate other little-relation to source data weirdness with synthetic
input.
commands to make the attached screenshot in grass6:
g.region -d # spearfish
# from addons:
r.surf.volcano out=gauss method=gaussian kurtosis=0.5 peak=5000
r.random in=gauss vect=gauss_rand_500 n=500
v.surf.idw in=gauss_rand_500 out=gauss_rand_500.vidw column=value
plot:
d.mon x0
d.resize w=666 h=1006
d.font Vera
d.split.frame frames=2
d.frame uno
MAP=gauss
r.colors "$MAP" col=bcyr
d.rast "$MAP"
d.vect gauss_rand_500 icon=basic/point fcolor=none color=60:60:60
d.legend "$MAP" at=5,60,2,5
echo "$MAP" | d.text color=black size=4
d.frame dos
MAP=gauss_rand_500.vidw
d.rast "$MAP"
fwiw I also notice that the module does not scale well to large region
sizes (at all).
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2016>
