[GRASS-dev] i.gensiget: "Unreliable clustering. Try a smaller initial number of clusters"
Nikos Alexandris
nik at nikosalexandris.net
Fri Jun 28 07:40:47 PDT 2013
Hi!
Today using i.gensigset, I bombed into this strange behaviour as the one
discussed in the past
<http://lists.osgeo.org/pipermail/grass-user/2010-April/055639.html>
where the module did not generate any signatures. Anyone that knows what's
going on? I have tried various stuff without success.
I also tried in the "imagery60/user1" location/mapset using the Spot subsets
(spot.ms.1, spot.ms2, spot.ms.3), and it just works fine!
Thanks, N
A test-case:
# where am I
g.proj -p
-PROJ_INFO-------------------------------------------------
name : Universal Transverse Mercator
proj : utm
datum : wgs84
ellps : wgs84
zone : 48
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
# region
g.region -p
projection: 1 (UTM)
zone: 48
datum: wgs84
ellipsoid: wgs84
north: 178800
south: 137200
west: 163500
east: 225200
nsres: 100
ewres: 100
rows: 416
cols: 617
cells: 256672
# Top of Canopy Reflectance (from a Landsat 7 scene)
for Band in `g.mlist type=rast pat=ToCR?`; do r.info -r ${Band}; done
raster map(s) available in mapset <classification_trials>:
min=0.00124375210840126
max=0.35849866608563
min=0
max=0.35782345515399
min=0
max=0.379788238688478
min=0.00243176894430602
max=0.467877978869486
min=0.00498972477821269
max=0.405811742521198
min=263.377037572447
max=301.084746200043
min=0.00636355695948437
max=0.457282493983423
# a random samples map lies inside
r.info -gr random_trainingmap
north=178800
south=137200
east=225200
west=163500
nsres=100
ewres=100
rows=416
cols=617
cells=256672
datatype=CELL
min=1
max=5
# and is not empty
r.stats -cp random_trainingmap
100%
1 155 0.06%
2 203 0.08%
3 90 0.04%
4 45 0.02%
5 104 0.04%
* 256075 99.77%
# grouping ToCRs
i.group group=spectral subgroup=123457
input=ToCR1,ToCR2,ToCR3,ToCR4,ToCR5,ToCR7
# attempting to generate signatures
i.gensigset trainingmap=random_trainingmap group=spectral subgroup=123457
signaturefile=123457
Finding training classes...
100%
5 classes found
Reading raster maps...
100%
Clustering class 1 (155 pixels)...
WARNING: Removed a singular subsignature number 1 (4 remain)
WARNING: Removed a singular subsignature number 1 (3 remain)
WARNING: Removed a singular subsignature number 1 (2 remain)
WARNING: Removed a singular subsignature number 1 (1 remain)
WARNING: Unreliable clustering. Try a smaller initial number of clusters
WARNING: Removed a singular subsignature number 1 (-1 remain)
Number of subclasses is 0
Clustering class 2 (203 pixels)...
Clustering class 3 (90 pixels)...
Clustering class 4 (45 pixels)...
WARNING: Too many subclasses for class index 4
Number of subclasses set to 4
Clustering class 5 (104 pixels)...
i.gensigset complete.
