[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler neteler at osgeo.org
Fri Jun 28 13:14:57 PDT 2013
Evviva!!
GRASS 7.0.svn (nc_spm_08_grass7):~ > g.version -g
version=7.0.svn
date=2013
revision=56943M
build_date=2013-05-28
GRASS 7.0.svn (nc_spm_08_grass7):~ > uname -a
AIX login01-hf0 1 7 ...
On Fri, Jun 28, 2013 at 9:37 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> Oops, LDFLAGS should probably be
> LDFLAGS="-Wl,-bsvr4,-R,/opt/freeware/lib -L/opt/freeware/lib"
Perfect guess :)
> Alternatively, try to disable nls, i.e. do not --enable-nls during
> configuration.
(it was already disabled)
So, at this time we may actually USE the latest GRASS GIS 7 on this
TOP500 supercomputer! To me the frontend node looks already nice:
vmstat
System Configuration: lcpu=96 mem=193280MB
So, time to study IBM's LoadLeveler now for parallel GRASS jobs.
Thanks for all your support, I'll update the GRASS Wiki accordingly
(although there isn't too much to add since most changes are already
in SVN).
Cheers
markusN
