[GRASS-dev] pyGRASS strange error on loading raster modules shortcuts
Pietro
peter.zamb at gmail.com
Fri Jun 28 14:00:56 PDT 2013
Hi Yann,
I've compiled python2.6.6 and installed on my user home.
Then distclean and re-copile grass7 and it is working on my machine,
as you can see:
GRASS 7.0.svn (nc_basic_spm_grass7):~ > python
Python 2.6.6 (r266:84292, Jun 28 2013, 19:43:23)
[GCC 4.8.1] on linux3
Type "help", "copyright", "credits" or "license" for more information.
>>> from grass.pygrass.modules.shortcuts import raster as r
>>> from grass.pygrass.modules.shortcuts import imagery as i
>>> from grass.pygrass.modules.shortcuts import display as d
I don't know how can I help you to solve this problem...
> Traceback (most recent call last):
> File "/usr/lib64/python2.6/sre_compile.py", line 352, in _optimize_unicode
> mapping = array.array('b', mapping).tostring()
> TypeError: __new__() takes at most 2 arguments (3 given)
As you can see the error is raised from the internal libraries of python...
Maybe you can try re-compiling and installing python locally in your home...
Best regards
Pietro
