[GRASS-dev] [GRASS GIS] #1872: r.in.wms doesn't work on Windows
trac at osgeo.org
Sat Jun 29 04:50:57 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.in.wms | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by hamish):
it is worth re-testing since the script called from within another script
winggrass bug was recently fixed. that was for .bat wrappers in grass6
though, so may not apply to trunk.
also for locations using a grid file for the datum transform note the bug
that there is no way to pass the path to a NTv2 grid filename to cs2cs if
the path has a space in it, which can cause m.proj to fail. we should
probably submit a quoting patch to proj4 to get that eventually fixed.
... and a reminder that r.in.wms2.py does not run from grass6 addons,
still needs more porting work done on it.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1872#comment:3>
