[GRASS-dev] [GRASS GIS] #1997: i.landsat.toar for grass-dev is missing the option for landsat8
trac at osgeo.org
Sun Jun 30 14:01:20 PDT 2013
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.landsat.toar | Platform: All
Cpu: Unspecified |
Comment(by nikosa):
Replying to [comment:6 vesnikos]:
> some minor bugs during my tests:
> 2) Band8 (panchomatic) has my nature 15m res. The algorithm uses the
regions resolution , and you cannot do anything to override it.
You can set the region resolution to the desired one! In my scripts I do
that. Maybe in this case an exception could be done and let the module
handle this?
> 3) timestamp in r.info reads none, the date of acquisition is in the
metadata, so it should be properly implemented
This would be also nice!
> eg: r.timestamp map=LC81840322013143LGN03_B10.toarr.1 date="$(date
-d'$DATE_ACQUIRED $SCENE_CENTER_TIME' -u +'%d %b %Y %H:%M:%S.%N %z')"
You can get the date using
i.landsat.toar -p metfile=MTLFile.txt lsatmet=date
and the ''decimal'' time
i.landsat.toar -p metfile=MTLFile.txt lsatmet=time
though, the "input_prefix=Dummy" and "output_prefix=Dummy" must be
defined.
For the records, if you import Landsat bands using the script found in
GRASS-Wiki
[http://grasswiki.osgeo.org/wiki/LANDSAT#Automated_data_import], the
timestamp is set correctly. However, i.landsat.toar does not take care to
copy this over. Even, the right way would be to grep the info from the
MTL file directly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:7>
