[GRASS-dev] [GRASS GIS] #2018: Provide a way to edit the PERMANENT/MYNAME file
trac at osgeo.org
Sun Jun 30 17:00:29 PDT 2013
Reporter: nikosa | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: unspecified
Keywords: location, description, ps.map | Platform: Unspecified
Cpu: Unspecified |
Comment(by hamish):
Currently it's settable at the time that you create the location, after
that you need to edit the text file by hand.
in grass6 I'd add editing it as an option to g.setproj, not g.proj. Code
should be very similar to several r.support options. Not sure about in
grass7, I feel g.proj is already a bit overloaded wrt functionality, but
it's not enough for its own g.support module.
it's generally set-and-forget, so doesn't belong in g.gisenv as a
variable.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2018#comment:1>
