[GRASS-dev] [GRASS GIS] #1900: limiting display vector map using cats doesn't work
trac at osgeo.org
Fri Mar 1 02:37:32 PST 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: invalid | Keywords:
Platform: Linux | Cpu: x86-64
Comment(by martinl):
Replying to [comment:1 mlennert]:
> If you want to use the cat or select option, you have to select the
specific layer you want to select features in. In grass6 this is layer 1
by default, but this is no longer true in grass7 where -1 (i.e. all
layers) is the default (since r45095 two years ago) and so you have to
explicitely select the layer. See also [http://lists.osgeo.org/pipermail
/grass-dev/2011-September/055675.html this thread] where the issue was
discussed.
seems like a "tricky feature" even for powerusers. When selecting features
(by cats, etc), should be probably selected features from all layers
(`layer=-1`) which pass the condition, not all features (silently ignoring
given condition or constraint).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1900#comment:3>
