[GRASS-dev] [GRASS GIS] #1901: v.mkgrid near ", ": syntax error, no batch insert
trac at osgeo.org
Fri Mar 1 04:07:17 PST 2013
#1901: v.mkgrid near ",": syntax error, no batch insert
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.mkgrid | Platform: Linux
Cpu: Unspecified |
Changes (by marisn):
* keywords: => v.mkgrid
Comment:
Multirow inserts are valid since SQL-92. I would still stay on side, that
this feature should be left as is as speed difference on large grids is
enormous but non-SQL-92 RDBMSes are disappearing.
According to Wikipedia: "This feature is supported by DB2, SQL Server
(since version 10.0 - i.e. 2008), PostgreSQL (since version 8.2), MySQL,
sqlite (since version 3.7.11) and H2". Solution - upgrade sqlite.
Second option - add extra logic to switch to slingle row inserts if
multirow fails. Still I have no time now to implement it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901#comment:1>
