[GRASS-dev] [GRASS GIS] #1902: g.tempfile -d: make a directory not a filename
trac at osgeo.org
Sat Mar 2 04:13:06 PST 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: g.tempfile, scripting | Platform: All
Cpu: All |
in grass7 there is a new `g.tempfile -d` flag to do a "dry run". It is
used in core.py by grass.tempdir() to later make a directory by the
returned string name. This has three things against it: 1) it causes a
race condition. 2) it diverges from the usage of `/bin/mktemp -d`, which
is used to make a directory. 3) it's a lot more convoluted than just
making the tempfile a directory in the first place, which is the only(?)
known use of -d for dryrun.
I propose that the -d flag in g.tempfile be changed to match mktemp's
usage, i.e. make a directory instead.
It is not present in grass6, so there is not a backwards compatibility
problem to change it now. I'd suggest that the -d flag to make a new
directory would be useful to backport to grass6 once it is ready.
thanks,
Hamish
ps- argh trac is logging out every 5 minutes again
Ticket URL: <https://trac.osgeo.org/grass/ticket/1902>
