[GRASS-dev] [GRASS GIS] #1889: wxPy loc'n wiz: don't auto-launch into PERMANENT
GRASS GIS trac at osgeo.org
Sat Mar 9 15:47:11 PST 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  6.4.3 RCs
 Keywords:  location wizard  |    Platform:  Unspecified
      Cpu:  x86-64           |
Comment(by hamish):
 just tested with a fresh build of relbr64. After setting the region bounds
 it is still printing some g.region debug output to the terminal.
 when the create new mapset gui pops up, it would be good to have a few
 sentence tooltip available explaining what MAPSET means, and a [Help]
 button at the bottom that opened up $GISBASE/docs/html/helptext.html.
 > closing the ticket?
 not before it has been ported to all branches. (please don't do
 development work in the release branch and then not sync with the dev
 branches. The release branch must be treated with great care, only code
 tested in the relevant dev branch should be backported to the release
 branch- by backporting it to the release branch you're personally signing
 off that the code is tested and works. tx)
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1889#comment:14>
