[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute Table Manager
GRASS GIS trac at osgeo.org
Sun Mar 10 14:20:30 PDT 2013
 Reporter:  antonioall                         |       Owner:  grass-dev@…
     Type:  defect                             |      Status:  new
 Priority:  blocker                            |   Milestone:  6.4.3
Component:  wxGUI                              |     Version:  svn-develbranch6
 Keywords:  wingrass, attribute table manager  |    Platform:  MSWindows Vista
      Cpu:  x86-32                             |
Comment(by hellik):
 Replying to [comment:25 annakrat]:
 > Replying to [comment:24 annakrat]:
 > > According to the python doc, NamedTemporaryFile is automatically
 deleted after closing, that's why it's not closed in the code. I suggest
 using [http://docs.python.org/2/library/tempfile.html#tempfile.mkstemp
 tempfile.mkstemp] and use this [http://www.logilab.org/blogentry/17873
 advice].
 > Done in r55306 in release branch. I guess this problem affects all
 branches. Please test if it helped. I have no experience with temp files
 on Windows so maybe someone has better solution.
 thanks trying to find a solution. is editing within atm still greyed out?
 if yes, maybe this should also be changed that testing is available.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:26>
