[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute Table Manager
trac at osgeo.org
Sun Mar 10 23:44:36 PDT 2013
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wingrass, attribute table manager | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:27 annakrat]:
> Replying to [comment:26 hellik]:
> > if yes, maybe this should also be changed that testing is available.
> thanks, done in r55310. We must keep it in mind and reapply it if the
fix fails.
tested with
System Info
GRASS version: 6.4.3svn
GRASS SVN Revision: 55310
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
in the atm:
(1) adding coloumns (integer, double, varchar, datum) => works
(2) editing a row in the table => works
closing ticket?
thanks
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:28>
