[GRASS-dev] [GRASS GIS] #1782: wingrass7: installing addons by wxgui-extensions manager fails
GRASS GIS trac at osgeo.org
Mon Mar 11 03:56:38 PDT 2013
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  wxGUI             |     Version:  svn-trunk
 Keywords:  wingrass, python  |    Platform:  MSWindows 7
      Cpu:  x86-64            |
Description changed by neteler:
Old description:
> hi,
> following tested:
> Settings => Add extensions => Install extensions of [g.extension]
> - message box opens: g.extensions.py - choose the program to open this
> file
> - closing this message box, the wxgui "Fectch & install from GRASS-
> addons" opens
> - press button "Fetch", again message box "g.extensions.py - choose the
> program to open this file" opens
> - closing message box, an error message opens "Error: access denied"
> - press button "Command dialog", again message box "g.extensions.py
> - choose the program to open this file" opens
> - closing message box, the g.exteniosn-wxgui opens and pre-combiled
> addons binaries are installed
> Helmut
> System Info
> GRASS version: 7.0.svn
> GRASS SVN Revision: 53670M
> GIS Library Revision: 52468 (2012-07-27)
> GDAL/OGR: GDAL 1.9.2, released 2012/10/08
> PROJ4: Rel. 4.8.0, 6 March 2012
> Python: 2.7.2
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
New description:
 hi,
 following tested:
  * message box opens: g.extensions.py - choose the program to open this
 file
  * closing this message box, the wxgui "Fetch & install from GRASS-addons"
 opens
  * press button "Fetch", again message box "g.extensions.py - choose the
  * closing message box, an error message opens "Error: access denied"
  * press button "Command dialog", again message box "g.extensions.py
  * choose the program to open this file" opens
  * closing message box, the g.extension-wxgui opens and pre-combiled
 Helmut
 System Info
 Python: 2.7.2
 wxPython: 2.8.12.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1782#comment:1>
