[GRASS-dev] g.region adjust region bounds using meter in lat/lon location
SBL Stefan.Blumentrath at nina.no
Mon Mar 11 11:54:34 PDT 2013
Dear all
In a lat/lon-location, how could I possibly adjust region bounds based on a
given distance in meter.
In projected locations for example e=e+1000 s=s-1000 is a handy way doing
it.
But in a lat/lon-location bounds are given in Deg or DMS as a unit.
Are here any GRASS (or other OSGeo) tools I could use for calculating the
new region bounds in deg using a fixed distance around the old region or for
calculating the new bounds in a  e=e(deg)+1000(m) kind of way?
Thanks in advance!
Best regards
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/g-region-adjust-region-bounds-using-meter-in-lat-lon-location-tp5039713.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
