[GRASS-dev] [GRASS GIS] #1904: wingrass6.4.3svn: vector digitizing - a sort of incomplete
trac at osgeo.org
Tue Mar 12 15:29:51 PDT 2013
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Vector | Version: svn-releasebranch64
Keywords: wingrass, vector, digitizer | Platform: MSWindows 7
Cpu: x86-64 |
tested with
GRASS SVN Revision: 55310
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
taken from http://trac.osgeo.org/grass/ticket/1270#comment:30
starting to digitize a new vector, defining new columns (integer, double,
varchar, datum) works.
digitizing a new point, line or area, the window to enter attributes pops
up, but no fields to enter attributes are displayed, on the top of the
popup window there is the message "no attributes found".
furthermore, after finishing digitizing point, line and area, only the
boundary of the area is displayed ( an extra build topology doesn't help),
although there seems point, line and area inside the new vector.
and from http://trac.osgeo.org/grass/ticket/1270#comment:31
after a manually v.category input=testv at user1 option=add to the new
digitized vector, point, line and area are displaye correctly.
can anyone test it?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1904>
