[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Wed Mar 13 08:43:07 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:17 mmetz]:
> > Reverted in r55335.
> I am inclined to revert r55335 until a proper solution is found.
Reinstating the hack makes it less likely that a proper solution will be
found.
> > In what way does the DBMI client lib receive "garbage"? Is the data
simply corrupted, or does it bear absolutely no relation to what the
driver sends?
> The communication pipe first sends the size of the string, then the
string itself [1]. After the first few transmissions, the size of the
string as sent by the driver is correct, but the size of the string as
received by the dblib is too large.
That doesn't really help. What would help would be the actual bytes. But I
can hazard a guess based upon comment:19:
> Here garbage is received: the string length received is 1280 instead of
5:
5 = 0x00000005 = "\x05\x00\x00\x00"
1280 = 0x00000500 = "\x00\x05\x00\x00"
It appears that an extra character has been inserted somewhere in the
stream. The usual suspect is LF->CRLF conversion. That is supposed to be
prevented by linking everything against fmode.o, but it's possible that
isn't happening for some reason, or something else is overriding it. Also,
`G_gisinit()` and `G__gisinit()` explicitly set "_fmode = O_BINARY", but
those functions don't appear to be called by DBMI drivers (although they
typically call other libgis functions, e.g. `G__setenv()`).
But rather than guess, it would be better to instrument `db__send()` and
`db__recv()` to dump the data as hex.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:20>
