[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Wed Mar 13 14:42:51 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:20 glynn]:
> Replying to [comment:17 mmetz]:
> > > Reverted in r55335.
> > I am inclined to revert r55335 until a proper solution is found.
> Reinstating the hack makes it less likely that a proper solution will be
found.
Hmm. For the last 6 months this problem has been simply ignored. Anybody
trying to find a solution will have to modify to code anyway.
> It appears that an extra character has been inserted somewhere in the
stream. The usual suspect is LF->CRLF conversion. That is supposed to be
prevented by linking everything against fmode.o, but it's possible that
isn't happening for some reason, or something else is overriding it.
I get a compiler warning for fmode.c:
fmode.c:4:5: warning: '_fmode' redeclared without dllimport attribute:
previous
dllimport ignored [-Wattributes]
> Also, `G_gisinit()` and `G__gisinit()` explicitly set "_fmode =
O_BINARY", but those functions don't appear to be called by DBMI drivers
(although they typically call other libgis functions, e.g. `G__setenv()`).
Adding `G_gisinit()`, `G_no_gisinit()`, or "_fmode = O_BINARY", or any
combination of these to main.c of the drivers does not help.
> But rather than guess, it would be better to instrument `db__send()` and
`db__recv()` to dump the data as hex.
Attached as hexdump.txt for `v.info -c map=boundary_county`. Please let me
know if you want another format.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:22>
