[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Thu Mar 14 07:25:16 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:22 mmetz]:
> I get a compiler warning for fmode.c:
fmode.c:4:5: warning: '_fmode' redeclared without dllimport attribute:
previous
dllimport ignored [-Wattributes]
FWIW, MinGW provides a /lib/binmode.o file for this purpose. Can you try:
make FMODE_OBJ=/lib/binmode.o
> Adding `G_gisinit()`, `G_no_gisinit()`, or "_fmode = O_BINARY", or any
combination of these to main.c of the drivers does not help.
If our fmode.o is wrong, it may actually prevent the run-time _fmode
setting from working by introducing a new _fmode variable which shadows
the real one.
> > But rather than guess, it would be better to instrument `db__send()`
and `db__recv()` to dump the data as hex.
> Attached as hexdump.txt for `v.info -c map=boundary_county`. Please let
me know if you want another format.
Can you indicate whether the bytes are sent or received, and by which
process? Also: where is this data coming from? `db__send` and `db__recv`?
If so, the hexdump is even worse than the previous reports; e.g. the fifth
entry shows something receiving 38 bytes but there is no record of it
being sent.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:23>
