[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler neteler at osgeo.org
Thu Mar 14 14:38:05 PDT 2013
(back to list)
Ivan,
what's inside of this directory?
/gpfs/home/senko/dev/grass/grass64/dist.powerpc-ibm-aix7.1.0.0/include
There should be a grass/ directory with the include files inside.
The "make" output being:
"./include/Make/Grass.make", line 90: make: Dependency line needs
colon or double colon operator.
"./include/Make/Grass.make", line 92: make: Dependency line needs
"./include/Make/Grass.make", line 400: make: Dependency line needs
"./include/Make/Grass.make", line 403: make: Dependency line needs
"Makefile", line 53: make: Dependency line needs colon or double colon operator.
"Makefile", line 55: make: Dependency line needs colon or double colon operator.
"Makefile", line 57: make: Dependency line needs colon or double colon operator.
"Makefile", line 59: make: Dependency line needs colon or double colon operator.
"Makefile", line 61: make: Dependency line needs colon or double colon operator.
"Makefile", line 121: make: Dependency line needs colon or double
colon operator.
"Makefile", line 127: make: Dependency line needs colon or double
colon operator.
"Makefile", line 284: make: Dependency line needs colon or double
colon operator.
"Makefile", line 286: make: Dependency line needs colon or double
colon operator.
"Makefile", line 308: make: Dependency line needs colon or double
colon operator.
"Makefile", line 312: make: Dependency line needs colon or double
colon operator.
make: Fatal errors encountered -- cannot continue.
is unclear to me. Which make version do you use?
Hint: I would ditch GRASS 6 in favour of GRASS 7 on AIX since it comes with a
modernized Makefile system and many other advantages.
Best
Markus
