[GRASS-dev] [GRASS GIS] #1905: Import modules allow to import into northern UTM location southern data
trac at osgeo.org
Fri Mar 15 01:58:49 PDT 2013
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: v.in.ogr, r.in.ogr | Platform: Unspecified
Cpu: Unspecified |
Steps to reproduce:
* create a new location from EPSG code 32636
* create a new shapefile in QGIS with EPSG code 32736
* import shapefile with v.in.ogr
Import should fail as there's a "small" difference between UTM 36N and 36S
but GRASS just announces "location appears to match" and imports file.
Blocking release as it might cause hard to catch nastiness later and might
indicate more serious breakage in projection code matching. Sorry.
Tested on:
14th March WinGRASS 6.4.x 55376 (or whatever as it's not possible to copy
revision number)
Originally reported in ML. http://osgeo-org.1560.n6.nabble.com/bug-with-
projection-systems-td5040244.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/1905>
