[GRASS-dev] compilation of grass on AIX 7.1
Ivan Barka
ivan.barka at gmail.com
Fri Mar 15 06:09:27 PDT 2013
grass 6.4 dev branch:
> what's inside of this directory?
> /gpfs/home/senko/dev/grass/grass64/dist.powerpc-ibm-aix7.1.0.0/include
of course it is. There are just two files and two empty subdirectiores
PolimiFunct.h
waterglobs.h
vect/
iostream/
grass 7 trunk (configure: error: ***Unknown platform:
powerpc-ibm-aix7.1.0.0***):
> Is this a recent GRASS 7 source code version? I would not know
> why is works for you with GRASS 6 but not 7 since the OS detection
> scripts are basically the same.
> @devs: any idea?
It's actual revision 55393.
Ivan
2013/3/15 Markus Neteler <neteler at osgeo.org>
> (please keep this on the list)
> On Fri, Mar 15, 2013 at 7:55 AM, Ivan Barka <ivan.barka at gmail.com> wrote:
> > 2013/3/14 Markus Neteler <neteler at osgeo.org>
> > there are just two files:
> > Make
> > grass
> the latter should actually be a directory...
> > If I try to configure grass7, I get:
> > configure: error: ***Unknown platform: powerpc-ibm-aix7.1.0.0***
> @devs: any idea?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130315/887644bc/attachment-0001.html>
