[GRASS-dev] formatting expressions for r.mapcalc in GRASS6.4.3
Markus Neteler
neteler at osgeo.org
Fri Mar 15 07:06:31 PDT 2013
On Fri, Feb 15, 2013 at 2:29 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Helena Mitasova wrote:
>> > The wxGUI command line has its own rules (see shlex.split()
>> > in the Python library documentation).
>> running mapcalc through the wxGUI command line is where the students have problems in winGRASS
>> (but it works on Mac)
> Is this on Windows?
A guest in our group has currently the same problem:
r.mapcalc 'test_rmap=log(abs(elec_accum)+1)'
Under Windows it does not work with a "syntax error" message.
> gui/wxpython/core/utils.py has:
> def split(s):
> """!Platform spefic shlex.split"""
> if sys.version_info >= (2, 6):
> return shlex.split(s, posix = (sys.platform != "win32"))
> elif sys.platform == "win32":
> return shlex.split(s.replace('\\', r'\\'))
> else:
> return shlex.split(s)
> However: shlex.split(..., posix=False) will retain any quotes, while
> posix=True removes them:
> > shlex.split('a "b c"')
> ['a', 'b c']
> > shlex.split('a "b c"', posix=False)
> ['a', '"b c"']
> With posix=False, there doesn't appear any way to prevent splitting on
> whitespace without also adding quotes.
> From the above code, it appears that posix=False is used on Windows so
> that backslash characters in filenames are treated as literal
> backslashes rather than as escape characters. If that's the only
> reason, then removing the "if" case may suffice.
I don't know exactly how let our guest test that...
Markus
