[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Fri Mar 15 09:18:27 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:25 mmetz]:
> Do we need to add this globally, i.e. to gisinit()?
I don't think so. stdin/stdout are normally text streams, so we probably
want the CRLF<->LF conversions.
> BTW, I think that `lib/dbmi_driver/driver.c` should be in
`lib/db/dbmi_client/` for consistency, or IOW there were
`lib/dbmi_client/start.c` is. It seems that `lib/dbmi_driver/` should only
include db_d_* functions.
Drivers should be linked with -lgrass_dbmidriver and -lgrass_dbmibase.
Clients should be linked with -lgrass_dbmiclient and -lgrass_dbmibase.
dbmi_driver should contain functions which are only of use to drivers,
dbmi_client should contain functions which are only of use to clients,
dbmi_base should contain functions which are of use to both.
db_driver() is the core of a driver's main() function, and belongs in
dbmi_driver.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:26>
