[GRASS-dev] formatting expressions for r.mapcalc in GRASS6.4.3
Vaclav Petras
wenzeslaus at gmail.com
Fri Mar 15 12:31:31 PDT 2013
On 15 March 2013 20:08, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Mar 15, 2013 at 6:09 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Tell them to modify utils.py as described above,
> GRASS newcomers, hard to realize.
>> or provide them with a modified version.
> I'm not able to compile winGRASS. Perhaps it is "as simple" as replacing
> a file? Maybe better patch in SVN and wait for the nightly built...
I'm not following the discussion, so I don't know what to patch.
However, about the replacing, you can just replace the file in your
windows distribution and it will work without compilation (Python
recompiles pyc files automatically).
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
