[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
GRASS GIS trac at osgeo.org
Mon Mar 18 14:29:27 PDT 2013
 Reporter:  isaacullah                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  6.4.2
Component:  Display                     |     Version:  6.4.0 RCs
 Keywords:  v.digit ppm temp, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32                      |
Comment(by neteler):
 Replying to [comment:13 glynn]:
 > Replying to [comment:12 wenzeslaus]:
 > > Now, mkstemp is used for files which will be combined to resulting and
 then os.remove (grass.try_remove) is called. So, I'm not sure where is the
 problem (why temporary files are not removed).
 > On Windows, you can't remove a file if any process has it open.
 Could the removal be put into the shutdown sequence? Perhaps by putting
 the files
 in question into a (file based) list?
Ticket URL: <http://trac.osgeo.org/grass/ticket/560#comment:14>
