[GRASS-dev] [GRASS GIS] #1796: wingrass7: some db.*-modules fails with dbf as db-backend
GRASS GIS trac at osgeo.org
Mon Mar 18 15:41:34 PDT 2013
  Reporter:  hellik       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  blocker      |   Milestone:  7.0.0
 Component:  Database     |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  dbf
  Platform:  MSWindows 7  |         Cpu:  x86-64
Changes (by hellik):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:16 mmetz]:
 > Can you test again? The bug should be fixed with r55382.
 just a quick test with
 GRASS version: 7.0.svn
 GRASS SVN Revision: 55413
 Build Date: 2013-02-18
 GIS Library Revision: 52468 (2012-07-27)
 GDAL/OGR: 1.9.2
 PROJ.4: 4.8.0
 GEOS: 3.3.6dev
 SQLite: 3.7.10
 Python: 2.7.2
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 works here. closing ticket, reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1796#comment:17>
