[GRASS-dev] [GRASS GIS] #1759: Selecting maps in dropdown menu: slider to move up/down maps does not work
trac at osgeo.org
Tue Mar 19 07:48:16 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: map selection
Platform: Linux | Cpu: x86-64
Changes (by isaacullah):
* status: closed => reopened
* resolution: wontfix =>
Comment:
I know this is marked as "closed", but I do want to just chime in to say
that this a problem on ANY linux windowing system using overlay
scrollbars. That includes both Unity and Xfce, and perhaps several others.
Thus, anyone trying to use GRASS on these systems is going to run intot
this problem, and it is a BIG problem, as it renders GRASS basically
unuseable. This may be related to other, more deeper problems with GRASS
menus, but since there is such an easy, very non-invasive way to fix this
for most by adding the line:
export LIBOVERLAY_SCROLLBAR=0
to the grass startup script, why not just do that by default?
~Isaac
Ticket URL: <https://trac.osgeo.org/grass/ticket/1759#comment:5>
