[GRASS-dev] compiling grass 7.0 fails
Sören Gebbert
soerengebbert at googlemail.com
Wed Mar 20 01:23:19 PDT 2013
sorry, that was my fault. I have committed the correct 3D raster
library header files. Revision 55464 should work now.
Best regards
Soeren
2013/3/20 Paulo van Breugel <p.vanbreugel at gmail.com>:
> Hi, I am trying to compile grass 7.0 (revision 55463). I am getting a lot of
> errors, with the first folder with error the 'lib/raster3d'
> Going there and running make gives me the following:
> gcc -g -O2 -fPIC
> -I/home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
> -o OBJ.x86_64-unknown-linux-gnu/changeprecision.o -c changeprecision.c
> changeprecision.c: In function ‘Rast3d_change_precision’:
> changeprecision.c:35:5: error: too few arguments to function
> ‘Rast3d_get_compression_mode’
> In file included from
> /home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/raster3d.h:261:0,
> from changeprecision.c:5:
> /home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/raster3d.h:82:6:
> note: declared here
> changeprecision.c:36:5: error: too few arguments to function
> ‘Rast3d_set_compression_mode’
> /home/paulo/Software/spatial/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/raster3d.h:81:6:
> note: declared here
> changeprecision.c:50:5: error: too few arguments to function
> note: declared here
> make: *** [OBJ.x86_64-unknown-linux-gnu/changeprecision.o] Error 1
> Any ideas?
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
