[GRASS-dev] compilation of grass on AIX 7.1
Markus Metz
markus.metz.giswork at gmail.com
Wed Mar 20 03:50:05 PDT 2013
On Wed, Mar 20, 2013 at 11:08 AM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Wed, Mar 20, 2013 at 10:17 AM, Ivan Barka <ivan.barka at gmail.com> wrote:
>> Hi devs,
>> so now I can configure G7 (revision 55464) on AIX 7.1 by command:
>> export PATH=$PATH:$HOME/apps/bin
>> CFLAGS="-lstdc++" ./configure --prefix=$HOME/apps
>> --with-proj-includes=$HOME/apps/include --with-proj-libs=$HOME/apps/lib
>> --with-proj-share=$HOME/apps/share --with-gdal=$HOME/apps/bin/gdal-config
>> --with-libs=$HOME/apps/lib --without-tiff --without-png --without-opengl
>> --without-tcltk --without-fftw --without-jpeg --enable-largefile
>> --without-postgres
>> output is in the attached file g7_configure_output.txt
>> Trying to compile g7 by "gmake" I get errors everywhere - see
>> g7_gmake_output.txt
>> The first one reports that install-sh can not be executed, I dont know
>> why...
> To be precise, install-sh can not execute line 239:
> "$doit" "$instcmd" "$src" "$dsttmp" &&
> On Linux, /usr/bin/install is used instead of install-sh, on Solaris
> /usr/bin/ginstall from GNU coreutils is used. It seems that you have
> the GNU C compiler on your AIX system, maybe you can also install
> ginstall?
>> gmake on this machine is GNU Make 3.80
> According to the requirements, this is too old. Version 3.81 released
> 2006 is the minimum required version. Can you update gmake?
GNU make 3.81 and GNU install are available in the official IBM AIX
toolbox as well as third-party AIX software repositories.
HTH,
Markus M
>> make is probably native AIX make, but I really do not know its version, make
>> -v does not work, nothing about it in man page. Trying to run make I get
>> only errors - see g7_make_output.txt
> On other UNIX-like systems (FreeBSD, Solaris) I found that make does
> not work with GRASS 7, only gmake (GNU make) works with GRASS 7.
> Markus M
>> thanks for any help
>> Ivan
>> 2013/3/18 Markus Metz <markus.metz.giswork at gmail.com>
>>> On Sun, Mar 17, 2013 at 11:08 PM, Glynn Clements
>>> <glynn at gclements.plus.com> wrote:
>>> > Markus Neteler wrote:
>>> >> > r39731 re-wrote it to use $host. Rather than trying to figure out the
>>> >> > correct $host value for each possible system (few of which were
>>> >> > available for testing), the sections for "unused" systems were
>>> >> > removed, with the intent that they would be added if and when someone
>>> >> > with access to such a system was able to report the correct $host
>>> >> > value and which compiler/linker switches actually worked on that
>>> >> > system.
>>> >> ... your help would be needed to re-enable AIX support.
>>> > The main thing that's needed is someone with:
>>> > 1. Knowledge of the correct $host string for that platform (this can
>>> > be obtained by running the config.guess script).
>>> Or simply running ./configure and report the error. Users trying to
>>> compile GRASS are, according to the official documentation, advised to
>>> run
>>> ./configure <optional custom options>
>>> make
>>> make install
>>> > 2. Knowledge of which compiler and linker switches are required to
>>> > build shared libraries on that platform.
>>> > 3. Access to the platform, for testing.
>>> > Each new platform needs to define the following variables:
>>> > LDFLAGS
>>> > LD_SEARCH_FLAGS
>>> > LD_LIBRARY_PATH_VAR
>>> > SHLIB_CFLAGS
>>> > SHLIB_LD
>>> > SHLIB_LD_FLAGS
>>> > SHLIB_SUFFIX
>>> > STLIB_LD
>>> > STLIB_SUFFIX
>>> > STLIB_LD and STLIB_SUFFIX have sensible defaults (building static
>>> > libraries tends to be the same on all systems). The others only really
>>> > matter for building shared libraries (LDFLAGS is also used for
>>> > building executables, but it can normally be empty).
>>> I would like to see support for at least FreeBSD (BSD is the
>>> predecessor of nearly all current operating systems), IBM AIX (a
>>> commercial unix-based OS), and HP-UX (another commercial unix-based
>>> OS). If we can adjust the G7 configure script to compile G7 on IBM AIX
>>> and HP-UX, we would be to my knowledge the only GIS package available
>>> for these high-performance operating systems, and I assume that we
>>> want G7 to be available on commercial high-performance operating
>>> systems.
>>> Markus M
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
