[GRASS-dev] [GRASS GIS] #1757: LD_SEARCH_FLAGS incorrect for NetBSD
trac at osgeo.org
Thu Mar 21 14:37:51 PDT 2013
Reporter: brook | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Other Unix
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:5 mmetz]:
> I think I discovered inconsistencies, if not errors, in the G7 Make
system: flags meant for cc are also passed to ld and vice versa, probably
because it is assumed that ld = cc.
Programs written in C are linked with $(CC). Programs written in C++ are
linked with $(CXX). Shared libraries are linked with $(SHLIB_LD). All
three are passed $(LDFLAGS). $(SHLIB_LD) is additionally passed
$(SHLIB_LDFLAGS).
In practical terms, this requires that both programs and shared libraries
are linked using the compiler front-end. The build system doesn't use
$(LD) (which is normally the underlying linker).
The main problem with separating the two is that configure doesn't attempt
to maintain any distinction, e.g. it only has one LDFLAGS variable.
Simlarly, "pkg-config --libs ..." will generate switches suitable for
passing to the compiler (i.e. with the -Wl, prefix).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1757#comment:6>
