[GRASS-dev] Rast_set_c_value question
Mon Mar 25 16:43:44 PDT 2013
Rashad M wrote:
> Does `Rast_set_c_value` set value of all cells in raster or individual cell?
Look at the code in lib/raster/raster.c.
It converts the CELL value given by its second argument to the type
specified by its third argument and stores the converted value at the
pointer given by its first argument.
> I have a code:
> s = Rast_cell_size(CELL_TYPE)
> Rast_set_c_value(outptr[i], int(tmpcell), CELL_TYPE)
> outptr[i] = G_incr_void_ptr(outptr[i], s)
> can anybody explain what this does?
The above code is logically equivalent to:
	*(outptr[i]++) = (int) tmpcell;
except that outptr[i] could be a CELL*, FCELL* or DCELL*, with the
actual type determined at run time.
