[GRASS-dev] compilation of grass on AIX 7.1
Markus Metz
markus.metz.giswork at gmail.com
Thu Mar 28 06:41:42 PDT 2013
On Thu, Mar 28, 2013 at 9:33 AM, Ivan Barka <ivan.barka at gmail.com> wrote:
>> Markus Metz wrote:
>> > >>> After renaming the variable "nearest" to "nearesta" in
>> > >>> lib/gis/plot.c it
>> > >>> worked.
>> > > I did the same on AIX 5.3 but we need a solution in SVN...
>> > Fixed in r55563.
> With r55565 I nave another error in lib/gis:
> gcc -lstdc++
> -I/gpfs/home/senko/dev/grass/grass7/dist.powerpc-ibm-aix7.1.0.0/include
> -D_FILE_OFFSET_BITS=64 -DGRASS_VERSION_DATE=\"'2013'\"
> -DPACKAGE=\""grasslibs"\"
> -I/gpfs/home/senko/dev/grass/grass7/dist.powerpc-ibm-aix7.1.0.0/include -o
> OBJ.powerpc-ibm-aix7.1.0.0/plot.o -c plot.c
> plot.c:34:1: error: expected identifier or '(' before '<<' token
Apparently you have local modifications that conflict with recent
changes in svn. The easiest is to delete plot.c and svn up again,
looking for any conflicts.
Markus M
> plot.c:36:1: error: expected identifier or '(' before '==' token
> plot.c:38:1: error: expected identifier or '(' before '>>' token
> plot.c:351:1: error: expected identifier or '(' before '<<' token
> plot.c: In function 'G_plot_polygon':
> plot.c:419:1: error: expected expression before '<<' token
> plot.c:421:1: error: expected expression before '==' token
> plot.c:423:1: error: expected expression before '>>' token
> plot.c: In function 'G_plot_area':
> plot.c:554:1: error: expected expression before '<<' token
> plot.c:556:1: error: expected expression before '==' token
> plot.c:558:1: error: expected expression before '>>' token
> plot.c: At top level:
> plot.c:636:12: error: static declaration of 'edge' follows non-static
> declaration
> plot.c:415:15: note: previous implicit declaration of 'edge' was here
> gmake: *** [OBJ.powerpc-ibm-aix7.1.0.0/plot.o] Error 1
> I tried also gcc -ansi, but then:
> in tools/timer:
> gcc -ansi -lstdc++
> -DPACKAGE=\""grassmods"\"
> OBJ.powerpc-ibm-aix7.1.0.0/main.o -c main.c
> main.c: In function 'main':
> main.c:22:20: error: storage size of 't' isn't known
> gmake: *** [OBJ.powerpc-ibm-aix7.1.0.0/main.o] Error 1
> in lib/gis:
> gcc -ansi -lstdc++
> -DGRASS_VERSION_DATE=\"'2013'\" -DPACKAGE=\""grasslibs"\"
> OBJ.powerpc-ibm-aix7.1.0.0/parser_interface.o -c parser_interface.c
> parser_interface.c: In function 'print_escaped_for_xml':
> parser_interface.c:54:5: error: unknown type name 'iconv_t'
> parser_interface.c:57:18: error: 'iconv_t' undeclared (first use in this
> function)
> parser_interface.c:57:18: note: each undeclared identifier is reported only
> once for each function it appears in
> parser_interface.c: In function 'G__usage_xml':
> parser_interface.c:118:28: error: 'CODESET' undeclared (first use in this
> function)
> gmake: *** [OBJ.powerpc-ibm-aix7.1.0.0/parser_interface.o] Error 1
> I am not C programmer, thanks for any ideas.
> Ivan
