[GRASS-dev] [GRASS GIS] #1768: wingrass6.x: python addon scripts aren't working
trac at osgeo.org
Wed May 1 16:22:02 PDT 2013
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Keywords: wingrass, python, addon | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
For g6 there is an include/Make/Python.make, which it is unclear to me if
it should be used for python addons scripts instead of re-using
(shell)Script.make?, even though there are not really any python scripts
outside of the special GUI cases there are ones in the g6 addons repo
which need it.
Likewise, for g7, Script.make has been repurposed for python scripts, but
some accommodation should be available for end-users' personal shell
scripts in some "Shell.make" or similar. There is a Python.make in g7 too,
but it just seems to run the .pyc compiler.
Also in the tools/module_svn_propset.sh script, there is an open question:
should .py scripts have the exe bit set or not?
AFAIK we are all in agreement that python scripts should have .py
extensions in the source code repo(s), then the *.make rules strip those
off at install time.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1768#comment:1>
