[GRASS-dev] [GRASS GIS] #726: MASK GRASS_INFO_WARNING
trac at osgeo.org
Wed May 1 18:53:39 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: invalid | Keywords: MASK, r.mask, startup
Platform: Unspecified | Cpu: x86-64
Changes (by hamish):
* status: new => closed
* resolution: => invalid
* component: Default => Raster
Comment:
Replying to [comment:1 pvanbosgeo]:
> I guess therefore that something has gone wrong when copying
> the mapsets and this is not a general bug. It would be good
> though to know if and how one can copy mapsets from a backup
> into the current location.
usually 'cp -rp' should do it; just make sure the location is identical
and any SEARCH_PATH in the mapset dir is in sync with the new layout.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/726#comment:2>
