[GRASS-dev] [GRASS GIS] #1730: GRASS 6.4.2 libgdal (GDAL 1.9.1) Disconnect
GRASS GIS trac at osgeo.org
Wed May 1 19:38:09 PDT 2013
  Reporter:  osgeodls   |       Owner:  grass-dev@…
      Type:  defect     |      Status:  closed
  Priority:  normal     |   Milestone:  6.4.3
 Component:  Packaging  |     Version:  6.4.2
Resolution:  invalid    |    Keywords:  libgdal.so
  Platform:  Linux      |         Cpu:  Unspecified
Changes (by hamish):
  * status:  new => closed
  * component:  Default => Packaging
  * platform:  Unspecified => Linux
  * keywords:  => libgdal.so
  * resolution:  => invalid
Old description:
> When trying to run GRASS 6.4.2 under Linux (Ubuntu 10.04 LTS) I get the
> following error message to the console on startup:
>  /usr/local/lib/libgdal.so.1: no version information available (required
> by /usr/lib/grass64/lib/libgrass_vect.6.4.2.so)
>  Is there a procedure 'fix' for this ? I downloaded gdal and compiled it
> to get rid of a prior error message from 'ogr2ogr' about a version
> mismatch but now when I launch gis.m I get: "g.proj or projection error:
> g.proj /usr/local/lib/libgdal.so.1: no version information available
> (required by g.proj) - g.proj: /usr/local/lib/libgdal.so.1: no version
> information available (required by
> /usr/lib/grass64/libgrass_gproj.6.4.2.so)  Can I assume this is a GRASS-
> only problem, as QGIS (1.9.0) seems fine with use of the PROJ library, as
> is ?
New description:
  "g.proj or projection error: g.proj /usr/local/lib/libgdal.so.1: no
 version information available (required by g.proj) - g.proj:
 /usr/local/lib/libgdal.so.1: no version information available (required by
 Can I assume this is a GRASS-only problem, as QGIS (1.9.0) seems fine with
 use of the PROJ library, as is ?
Comment:
 If you compile your own copy of GDAL, you should remove any gdal packages
 fro Ubuntu or UbuntuGIS, and recompile GRASS and QGIS from source code to
 match your new libraries.
 A GRASS built for a specific version of gdal only works with that version
 due to ABI/API compatibility issues.
 see the debian/README.debian file in the grass source code, and the
 compile and install pages in the grass wiki for hints on how to rebuild
 grass from source.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1730#comment:1>
