[GRASS-dev] [GRASS GIS] #1226: Grass should check and warn if g.region points to a zero area calculating range
trac at osgeo.org
Wed May 1 20:04:36 PDT 2013
range
Reporter: vesnikos | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: unspecified
Keywords: g.region | Platform: All
Cpu: Unspecified |
Changes (by hamish):
* keywords: => g.region
Comment:
I'm not able to reproduce the problem, how do you create a 0-area region?
(without manually editing the WIND file)
g.region w=0 e=0 n=0 s=0
ERROR: Invalid region: North must be north of South
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1226#comment:2>
